Having an issue with my Marantz 2285 bought new in 1977. Dial light went out and decided to send the unit off to be reconditioned as well as LED dial lights (everything worked fine on it except one dial bulb). Sent it to well known technician who knows his stuff around Marantz receivers. Got it back and had an issue with phono. Have a Marantz 6300 turntable. When I plug the jacks into the phono slot of the 2285 (with everything else plugged as original before I sent it off) and turn it to phono, get a loud oscillating humming noise (even with the turntable off). However, when I plug the turntable into my preamp (1300dc), it works fine. Shipped it back and he replaced the phono board and it worked fine for him (sent me a video playing a record...however, he did not have any other equipment plugged in). Nevertheless, when I got it back I had the same issue. And yes ,everything is grounded properly. Now, have spent a number of hours trouble shooting. Unplugged all RCA jacks plugged into the 2285 (Reverb, CD, Aux (Auris bluetooth), TEAC A3340S reel to reel... except for phono. Phono works fine by itself with the 2285. Slowly started adding back components...CD, Reverb, Aux...phono still works. It's only when I plug in the R2R with 4 RCA plugs (play and record in either Tape 1 or Tape 2) does the oscillation happens. Thought it might be the R2R, so I unplugged the R2R and plugged in the 5220 Cassette player, same thing...loud oscillation noise. Both the 5220 and R2R work fine on the 1300dc AS WELL as the Phono! CD works fine in either the Tape 1 or Tape 2 IN of the 2285. Therefore my non-technical conclusion is that there must be some type of interference or problem with the Tape 1 and/or Tape 2 OUT plugs with the Phono. Hope all this makes sense....any ideas or suggestions? The tech just says it is a mystery to him, so am at a loss. Thanks!
