steveo1960
So 2 quick questions..
1. Should the Dolby Light turn on if I hit the 2 micro switches behind the dummy panel assuming I have selected FM? I don't have a module.
2. What's the trick to changing the pointer light to an LED? I have a 3mm polarized LED and can see the pointer carrier has little tabs that look like they need to be bent back to access the light. I've searched far and wide and all I find are examples for other models using the large style carrier. I've wrapped the dial string in aluminum foil to fend off solder drips, heat etc.
Any advice, pointers? (pun intended!)
Tks!
Tks!
