2285B & those Main Ins
BrisVegas85b
Hi guys, I'm effectively running two systems in a room each with it's own set of speakers. 2285B for 2 channel, Yamaha V3800 HT receiver for ht duties
The ht receiver has pre outs which I can connect via rcas to the 2285's main in
rcas. My understanding is that will disengage the pre in the marantz. that's fine all cool. the speakers I wish to use are connected to the marantz...fine.
What happens then to the dedicated 2 channel sources I had previous attached to the 2 x auxiliaries on the 2285B.
Will these now not work because the old marantz detects an rca attached to the main ins and has therefore disengaged the pre internally.
New 2 channel amps have a ht bypass switch on the front that will switch the pre on and off. The 2285b doesn't have such a switch.
Help !!!! Can somebody please explain if this will work or not
Thanks
Wayne
When you plug cables into the Marantz "main in" rca jacks it effectively disconnects the Marantz preamp from the circuitry.
So anything you had going through the Marantz inputs will no longer be heard.
Thanks, so does it just have to have a physical connection to the main ins or
does there need to be an active feed ie. an actual signal coming into it.
if I turned my ht receiver off and nothing was coming out of those pre outs to the marantz's main ins, would the marantz still switch it's pre off
thanks for your help so far
When you plug in the cables into the jacks it physically breaks the connection inside the jack themselves.
Nothing high tech just an old school contact that is pushed away by the rca phono pin on the end of the plug.
Cool mate ... Thanks
bit of a bummer in a way !!
One possibility is to use a RCA splitter cable, connect the single end into the 2285B's MAIN IN, one set of split RCA jacks go to 2285B PRE-OUT, and the other pair of split RCA jacks goes to the HT PRE-OUT's. The signal won't be as clean, and if you have both sources going, they will be mixed into the output, but this will serve your purpose.
You can also buy (at least in the States, Radio Shack), a source selector box. Feed PRE-OUT from 2285B and the HT PRE-OUTs into that selector box, have the output from that selector box go into 2285B MAIN IN, and you will only have one source playing at a time.
If you are wanting to utilize the 2 channel components connected to the 2285, you should be able to run from the tape out on the Marantz to any available line in on the ht amp. The tape outs bypass the preamp and the main and should be available for use.
