Okay so I have a 2325 that had some issues when I got it. Relay would click on and off randomly amp boards offset would be around 53v and couldnt adjust to 0. Recapped amp boards, new heat sink transistors, resistors and output transistors etc. looks pretty damn good for my first time doing it. Checked over my work and instructions atleast 5x before installing. Relay will not engage at all now. Two spots on the amp boards are getting warm. ( see pics ) H715 as well as H706 & H707. The recap kit I bought came with ECB transistors for H707 and H706 so I bent the legs as instructed and installed.. H715 is ECB from the board diagram. Do I have H715 installed backwards ? See pic. Is H715 supposed to have the metal side towards the metal joint that screws into the heat sink ? I swapped in amp boards from another 2325 I have and the unit works perfectly. Btw, so its something on these pesky boards I re did
