richardg0n
Restoring a Marantz 2325, and the Balance Slider has no left-right separation. The volume is the same level except for the middle position, which is slightly louder. I tested with headphones on and with external speakers, and in both cases moving the balance slider potentiometer from left to right did not affect the volume output. It sounds like the balance slider has been bypassed so that it does not affect the left-right balance. See attached picks of the balance slider wiring. How can I determine if the balance slider has been bypassed? And if so, I would like to restore it to its intended purpose. See pics below.
These are the steps I have taken to troubleshoot the problem.
- Removed slider cover and used Deoxit D5 to clean tracks and contacts with a small brush; no change.
- Crossed the Main Pre RCA's in the back, and no effect on balance.
- I looked for loose or broken wires, and everything looked connected.
- Two wires from the green cable connected to the Balance slider are soldered reversed compared to the other 2325 balance sliders I have restored and connected to the Hi Pass switch on PU01. Not sure this is an issue.
