BossRadio4VR
Well, I ordered the LED's from the gent in Colorado off the auction site, and they arrived today. All but one of the lamps is working, and I suspect a deeper problem than just the LED replacement, because the stereo light on this unit wasn't working when I bought it, either. So I'm a little disappointed right there, because I'd been wanting to see the stereo indicator lit up.
I had a very stupid mishap when one of the powered pins on the function lamp board accidentally grounded to the chassis while I had the board out to replace the bulbs and turned it on to test them out. It was just for a couple of seconds, but this let some of the smoke out from somewhere in the front lower end of the unit, and imagine my surprise when I connected the speakers and it fired right up and it still sounds good. You gotta love Marantz... Nonetheless, I'll be shipping this thing off for a good once over and repair of whatever I fried with my carelessness.
Two things. I absolutely LOVE the dial and meter lights. But I equally dislike the bright white function lights. I liked that warm, parchment paper white look from the stock lamps. I think I can get used to the new look, but I'm going to try and neutralize the antiseptic look of those function LED's with some sort of filter. I think the seller should work on a next gen version of those dual pin bulbs to get a closer to stock appearance. It's funny how such a minor detail can color ones perception.
The color of the dial lights in this pic below appear more turqoise than they really are. The above picture is closer to accurate. I did no color correction, these were just straight off the camera. The actual color is more of what I would call a royal blue.
I removed the bulb, turned it over and resoldered it in place. :thmbsp:
