phollenback
I'm working on restoring a 2230b that's generally in good condition. The one major problem I'm trying to figure out is that it only has a left fm channel. I've tested other inputs such as AUX and they have both left and right sound. I also tried taking the audio directly from the preamp output and it behaves the same. AM radio outputs on both channels, and so do both tape inputs.
I've done the usual deoxit of the various selectors and pots.
I have the service manual and I've been poring over it for quite a while. I've checked voltages on the fm tuner chip on the p200 tuner board and it looks fine for both channels. I'm stuck at this point because I'm having a heck of a time figuring out where the left and right audio signals go from the p200 board. I've probably reached the limit of my ability to read circuit diagrams.
The STEREO light illuminates when I tune to a stereo FM station. Selecting REVERSE from the speaker output moves the output from the left channel to the right.
FM is only the one channel on the fm 25us setting as well, and I've verified operation of the microswitches in the dolby module slot.
If I turn the balance to the right and the volume knob to the max I can hear low volume and somewhat muffled audio on the right channel. Does this suggest a failed cap?
So, my guess is that something is going wrong after the HA1196 fm stereo chip, although I have yet to hook a scope up to the outputs from that chip to confirm.
Anyone have any suggestions for my next troubleshooting step?
