250M replacement transistors
goldswimmerb
Failed out of engineering, but look at me now!
Hey guys, I recently aquired a 250M with 1 blown output, which took out the corresponding predriver transistor as well as an exploded 2N4125 transistor. What are the recommended replacement transistors?
There’s probably more at fault here I’d rebuild the boards as these are problematic amps if they aren’t set up perfect lots of good restoration threads to look at
when I fixed my early 250, I checked *all* transistors on each amp board. many were blown (including outputs, the drivers, pre-drivers, ...).
I'd suggest a transistor checker, dbt, a couple DVMs, and a watt meter.
for the search challenged, here is my thread.
Thanks I really appreciate it
