2SC1885 NPN transistor replacement (TO92)
Dowhiteblack
Hi all,
i found in many threads here that the 2SC2911 substitutes very well the obsolete 2SC1885.
But it's a TO126 instead of a TO92.
Anyone knows a TO92 that would do the job ?
Thanks to all,
What is it going in? and where? - I have had a few instances now where the TO-92L package transistors are a bit over stressed by heat, changing to a different package is not a disadvantage unless there are severe space constraints.
@avionic, can i ask you how would you replace :
- 2SA968 (PNP | Pc 25 W | Vcb 160 V | Vce 160 V | Veb 5 V | Icmax 1,5 A | hFE MIN 170 | Package : TO220 |)
https://alltransistors.com/transistor.php?transistor=9123
- 2SA970 (PNP | Pc 0,3 W | Vcb 120 V | Vce 120 V | Veb 5 V | Icmax 0,1 A | hFE MIN 200 | Package : TO92 |)
https://alltransistors.com/transistor.php?transistor=9128
And just for the "pleasure" :
- 2SD745 (NPN | Pc 120 W | Vcb 140 V | Veb 5 V | Icmax 10 A | hFE MIN 80 | Package : XM20 |)
https://alltransistors.com/transistor.php?transistor=19992
- 2SB705 (PNP | Pc 120 W | Vcb 140 V | Vce 140 V | Veb 5 V | Icmax 10 A | hFE MIN 80 | Package : XM20 |)
https://alltransistors.com/transistor.php?transistor=10768
- 2SD588 (NPN | Pc 80 W | Vcb 150 V | Veb 120 V | Icmax 7 A | hFE MIN 40 | Package : XM20 |)
https://alltransistors.com/transistor.php?transistor=19750
- 2SB618 (PNP | Pc 80 W | Vcb 150 V | Vce 120 V | Veb 5 V | Icmax 7 A | hFE MIN 30 | Package : XM20 |)
Thanks a lot.
Warm regards,
These " batwinged " TO-220's are long gone and no longer available...
Maybe ---> MJL3281AG
Maybe ---> MJL1302AG
Maybe ---> MJE15032G
Maybe ---> MJE15033G
Thanks a lot.
Warm regards,
the D588/B618 I had replaced with FJP5200RTU and FJP1943RTU respectively. however, the 5200 seems to be no longer made and mouser has over a thou of the 1943 compliment, - go figure, however, if space is not a problem, they make the same spec in a larger power handling TO3P package
