Hello Everyone. I am planning on restoring an old Kenwood KA-6000 and have read probably a 100 threads on the dreaded 2SC458LG replacements and my head is spinning rapidly (although I've learned a lot so far). It seems a common replacement is the KSC1845, although some here on the AK say these may cause oscillation and to use the KSC1815 instead. But then I noticed reading the Kenwood manual that there are various "flavors" of the 2SC458's used. Most are "2SC458LG (B) or (C)". Some are just "2SC458B,C". But two (2) of them on the Pre-amp board are "2SC458LG (D)".
Looking at the datasheet, the 2SC458LG (D) version has the highest hfe of 250-500.
That brings me to the KSC1815YTA (readily available at Mouser), which states the Y version has an hFE classification of 120-240. I don't think the GR's or L's are available anymore.
Is it going to be an issue to use the KSC1815YTA's due to a lower hFE?
If I were to use the KSC1845FTA, also readily available at Mouser, in which application do I need to worry about Oscillation issues? (i.e. Main Amp, Pre-amp, ?).
Which is a better substitute ? Or do I select based on each application listed (B or C vs D)? Or something different altogether? (I've considered 2SC2240BL's but these are only available on eBay and I know most people's opinions on buying on eBay).
Any help is greatly appreciated. Not sure if this should be posted here or in the Kenwood thread, but figured I'd start here.
Thanks.
Marc
Thanks.
Marc
