I have 5 NOS 2SD218 transistors that I tested on a PEAK DCA55 and the gains are 30, 8, 16, 6 & 23. Also, the transistor with a gain of 6 is showing "Resistor Shunt Between B-E". I'm not going to use these on the intended project because the values are all over the place. What would be considered acceptable values using the DCA55?
