inperson
I just bought this amp about a month ago. Long story short, the mA meters line up dead center (50) for all the tubes I used so far (Shuguang and Valve Art) but when I use mesh plate Full Music 300B n/c tubes the meters don't match and the sound is also unbalanced. I don't know why. The amp is self-biasing the only adjustments I can make are some hum pots behind the 300B tubes. Yes, they are hum pots, not biasing pots. I asked the seller about it and they just said Full Music tubes aren't good. I also exchanged the first pair of Full Music 300B tubes for another pair but got the same bad results. The amp sounds great and I feel those mesh plates sound best but they don't seem to work with this amp. The amp uses two 300B tubes, 2 OB3 tubes, one 5U4 and two 6SJ7's.
Any ideas? I would love for someone to give their thoughts!
The second picture shows the best setting the Full Music tubes reached in the meters, but usually they are not this close. I have left the amp on to warm up for over 30 minutes but no change in the meters.
