jd3rdcoast
Hi All, I am trying to finish up a Model 3300 Preamp that was restored by someone. Was brought to me not passing signal on right side. All transistors on the Phono/X10/Tone boards had been replaced with KSC1845 and KSA733's. I did locate a PNP transistor that was in backwards on the X10 Board. It was Right Channel Q406 (PNP) that had a KSA733-C installed wrong because it is a E-C-B pinout. All others were KSA733 E-B-C. Also, I touched up all the solder joints for the 3 boards on the Interconnect board. I also was having a popping noise crop up after fixing that transistor on Right side. I noticed the +Vcc was jumping around when hot, traced to the +Vcc regulator on P/S board. The Base leg fell off when desoldered due to corrosion. They were original S36049/S36048 that I replaced with 2N3440/2N5416 I had in stock. +/-Vcc now stable 18V.
Everything seems to be working fine other than when the Tone switch is moved from Flat to IN or IN back to Flat, I get a Positive audible pop which can be seen on scope. Also, I get a pop each time I move the Hi-Filter Switch from Out to either setting. Negative blip going from Out and Positive blip when coming back to OUT position. No other switches cause any audible popping.
I am also seeing on scope about a 20mV high frequency waveform on both channels with VOL at rest if the TONE is IN. When Hi-Filter is engaged, the noise amplitude increases slightly. But If I start to raise the volume the noise quickly diminishes and goes flat by the time VOL reaches the 9:00 position and moving the Hi-Filter or Tone switch does not create a pop.
Wondering if anyone else has ever seen this type of anomaly on the 3300 or have a suggestion? Here is pic of Left side Hi Filter on X10 and Tone circuit. The yellow trace path is when Tone is Flat (No noise and no pops).
