340B bias adjustment...
Steelman
Got my 340-B recaped, new selenium rectifier installed (Thanks again Avaionic) and just powered it up using my DBT...all good :banana:
Can anyone steer me to a thread that details setting the bias please. This unit has bias test points at the top right corner and would like to get this one dialed in just right :D
Positive to the test point negative to chassie, 70 ma. I usually bias mine just below. Check a few additional times after tubes are all settled in (if new) and after receiver has been operated for some time. turn adjustment pots. Very little movement of the pot is usually all that is needed. These are nice receivers when all up to snuff.
Very fine receiver and a very cramped area under that chassis! I am in the process of moving and don't have mine up and running right now. Here is the one I bought many years ago. It has a Mahogany cabinet. Most of them have the Walnut which I actually prefer. Please enjoy this wonderful receiver. They don't make them any more :tears:.
If I understand it correctly...
Move impedance jumpers to 16ohm position?
then make this adjustment?
Thanks for the help
Very nice unit :thmbsp:
Once I have the unit up to spec, I am going to order a new dial glass and brites for the knobs...:D
Thanks for the help
Simply hookup your 8 ohm test speakers to provide load to your output tubes. You can use a 16 ohm 10W resistor if you like.
What about doing a cathode bias? I'm familiar with the LK-72B which with the help of the members, I just restored and bias'ed not too long ago. Install a 10 ohm 1/4 watt resistor at pin 5 and measure current drop across resistor. Remove the pair of 3.3 ohm resistors as well. All adjustments are made using the original Bias and Balance controls. Set current draw to 30 mA per 7591 and you are good to go. I'm not sure if this applies to the 340B, perhaps someone will chime in with a definitive answer.
I will give it a shot...thanks :thmbsp:
Do not set your meter on current to measure the bias, you will blow the fuse in your meter. The test points are to measure the current by measuring the voltage drop across the cathode resistors. The cathode resistor is 3.3 ohms, so 70mA x 3.3 = 231mV.
Very important point. It is kind of like measuring the current via remote control AKA Ohm's Law. 10 ohm resistors just make the math easier to understand for some of us, myself included.
So, using my 8ohm speakers and testing at the test points, I should see about 231mv on my meter...correct?
70mA x 3.3Ohms = 231mV because Ohms law is R = V/I (note for the OP)
A step by step guide how to setup the bias on a tube amp available here at VTL: http://www.vtl.com/pages/bias.html
That makes sense. If the output voltage from the bias supply is higher than original, the bias will be higher (more negative) which will bias the tubes into less conduction (current flow). Try measuring the voltage across one of the 12AX7 tubes and see if you get 12 VDC or a higher voltage.
Thanks very much :thmbsp:
Somethings amiss...
The unit sounds amazing but I just tested the cathode current at the test points and got this:
Left channel: 162.3mv
Right Channel: 176.9mv
162/176 is close enough matching for no audible differences or strain on the amp. But if you have Bias pots on each channel to set the idle current you can fine tune it and have it perfect.
BTW more idle current = more speed = more heat = less tube/tranny life span.
Also measure your amps DC offset also to make sure after you set a new bias values you haven't introduced distortion.
http://www.audiokarma.org/forums/showthread.php?t=5634&page=1
I will...thanks :thmbsp:
Well, the unit has been playing for the past three hours and I have had a smile on my face from ear to ear. I have it hooked to a pair of Advent 1's and the bass is very strong without being flabby, the mids are very clean and the highs are crisp without being brittle. I can't wait to hook it up to my JBL L40's and see where that goes.
The values posted earlier have been rock steady. None of the tubes seem to be red-plating and the iron is just a bit warm to the touch. I realize the cathode test points at the top of the unit are a rather laymen way of checking but beyond that I am unable to test any further. Others have mentioned to test across one of the tubes or check B+ but these terms elude me.
I think I will close it up, order the new dial glass and knob brites and get it in my rig on Monday. I think I will also run this one without tube shields or the wood case to vent the heat a bit more efficiently and the glow will look amazing.
Thanks to all for the help.
170mV is almost half the bias current. The bias is adjustable, the controls are right on top of the chassis and are marked, unless the writing rubbed off. Adjust for the proper bias. If not you get higher distortion and lower power output, because the tubes are running too low on their operating curve and will clip at a lower output on the negative half of the wave forms. Per the data sheet for the 7591, it is designed to operate at 60mA per tube in class AB operation. Scott's spec of 70mA is actually both tubes combined, or 35mA per tube. You run no risk of reduced tube or transformer life at this current, it is very conservative.
Thank you very much...I will adjust them to 231 as you suggested earlier right now...
