3D Acoustics 3D6/10B model
mrswakka
AK Subscriber
Picked these up 2 weeks ago. Took a few days to get them hooked up.
Boy Howdy!
These are really nice speakers. The satellites are extremely heavy and solid. So solid that it really doesn’t matter how close or far they need to be from a wall. Doesn’t matter in the slightest.
The passive sub is very smooth. It doesn’t go as low as my DCM DoubleTime sub, but it probably needs some playing time to loosen it up.
I would have to say these are great speakers! I’m playing NIN Terrible Lies, Highs are very detailed. The sub handles the long bass notes very, very well. These 3 speakers sound much, much bigger than they are. If you see a set of these, give them a listen.
Only negative I can come up with is they are moderately efficient. But give them some watts and they become very impressive. Seriously.
And they look damn nice too, real walnut veneer.
The only question I have is, how in the hell did I end up with 4 big passive subs in my living room?
I should say mrs wakka took this picture and said the title should be, speakers, speaker wire and STEELERS. There a 8 speakers in this photo. Can you find them all?
A giant killer they were called, I have some experience with these. Some quick facts, they love clean hi-power 150 + to sing. The sub is crossed at 90 hz and if 1st generation they will have Audax soft silk domes that sound amazing and allow some spooky highs and separation. They need a minimum of 3ft off the floor and 6ft of separation between satellites. The only con is well first if you listen to them with honestly ,I found they let you shut the off the critical thinking and just listen. I have smoked the tweets before pushing them too hard. Good luck
Update on these speakers. They beat out the DCM TW3s. They are extremely accurate. I’m constantly hearing details I never knew existed. Crazy.
On a side note, I added the dbx sub to the mix. 2 big passive subs sounds so cool.
I’ve gotten fond of passive subs. Using 2 different sizes is amazing. I understand these are not audiophile quality. I get it. But tell that to my chest that is feeling every beat on Low Rider by WAR!
Damn.
They‘re pretty inexpensive, and most of them don’t care where you put them. I figure if some old sub wants to still have fun after 40 years, you know.
I‘m looking at an A/D/S Sub 6 this weekend. I think it might pair up well with either halftimes or timepieces.
We finally hooked up the a/d/s sub 6. Paired them with timepieces. Sub is actually about the same as the timepieces, little taller, a lot heavier.
Boom, instant bottom. No adjustments, no phasing, no need for an electric plug.
I understand they were made a long time ago. But have you ever heard one on a great amp? And for what they’re selling for?
That dbx won’t rattle the windows, but it will compress your chest.
Anyway, the a/d/s sounds pretty good, and who knows how long it’s been used. I like breaking in old subs.
We’re in the process of integrating our Quadraflex sub into our Marantz 2250 system. We got a Crown amp to use with it. Hopefully our good friend lqpete11 will feel better. He’s got some physical issues and could use some positive vibes. He’s a good and honest friend.:angel:
Anyway, 15 inch paper cone. The case weighs a little over 80lbs. The rubber surround is amazingly thick. It hadn’t been played in years. Just 2 knobs on the back labeled “Centering”. I have a lot of free time. Probably too much. But, in endless fiddling with them, I eventually figured out these were actually early attempts at an active crossover. You tune it to your preference in minutes.
And those paper cones are still readily available.
And those paper cones are fast! Really fast. 15 in of solid front facing bottom. Yes, it is big. But the payoff is worth it. It was amazing on our Sansui AU 717, I can’t wait to hear it with the Marantz with the Crown amp…
For what I’m paying for these old subs, the value is astounding.
I paid $60 for this sub.
It was a great Friday! lqpete11 felt good enough to make the trek up here. He hooked up the Crown D-150A amp in with the Quadraflex Sub. It sounds great! I know the Crown amp is only 80 watts is pretty small compared to some powered subs. But it’s a real nice sound.
When you add the Pioneer SG-9500 lqpete11 brought up as an early Christmas present. It’s a great Eq. The slides are the smoothest thing ever.
On a side note, when we were working on the Marantz setup, we were listening to the Sansui AU717. He had unplugged the power conditioner, which killed the WiFi. Since I’m using an iMac as my digital source, music keeps playing with no internet. No buffering. Even the smallest iMac has a huge HD.
I just download all the music, have space to kill. I find something on iTunes, it syncs to all 3 Mac’s I’m using. $100 each. For a remote, I use the Bluetooth keyboards they came with.
It’s a high output system when you consider how much I didn’t spend.
.. Since I’m using an iMac as my digital source,..I find something on iTunes, it syncs to all 3 Mac’s I’m using. $100 each. For a remote, I use the Bluetooth keyboards they came with.
If you're not already familiar with it you can use the "iTunes Remote" app as well.
I run a Mac Mini in headless mode and control it with said app on an old iPad have been for years and works like a champ.
And oh yeah I almost forgot, STILLERS!!!!!!
I know about the remote app, but I have 3 Mac’s, so I just use the keyboards.
They have 6in woofers with a 1in soft tweeter. I can put pictures later if you’d like.
Had about 20 minutes of, oh no. Started hearing a buzzing. Turns out the sub was vibrating my keys which are in a bowl near the sub. :rockon:
Was finally able to hook up the 3D Acoustic Cubes. Very nice speakers! Using a cheap little Class D amp we use when looking at speakers. They are very well rounded speakers. Nice bass, very clean highs.
And just like the 3D6, it’s very accurate. Very natural sound. And I know they haven’t been played in a very long time, so they will only get better. At this point, I’d select these over TimePieces.
I’m thinking about pairing them up with a Small DCM powered sub.
Also tested the Fanfare Prelude speakers. But they need some attention, so we’ll reserve judgement on those for the time being.
If you come across any 3D Acoustics, I’d definitely take a look at them dude.
Well, we’ve been listening to the 3D Acoustics Cubes for a couple of weeks, I figure they’re pretty broke in.
Nice speakers! Really wide sound to them. They. Like their cousins the 3D6, they are very accurate speakers. I mean very accurate.
Example, the Queen song, Someone to Love. So many voices singing at once. On my 3D speakers, you can hear every single individual voice.
Know what can’t? DCM TW 3s. Coming off a Sansui AU 717. While the DCMs have much more bass, as far as clarity, it isn’t even close.
For such a small pair of speakers, they really like it when you turn it up a bit. They seem to really enjoy Grand Funk Railroad.
Go figure.
Trying out the 2nd pair of Cubes. These really are great speakers! One big difference, the first pair have a wrap around grill, while the second pair have 2 wooden strips on the front with a square grill held on with Velcro.
I’m curious as to why the change on such a small run of speakers? The new pair really bumped up the bass as well. Both sets are going to be recapped in the next couple of weeks. So we’ll see if there are any differences in the crossovers.
And I have no idea which came first.
Another post in the never ending evolution. We were finally able to get the DBX amp hooked up. Our friend lqpete11 is always the best dude.
So the DBX amp, A/B 150 watts. Small, simple. Greg put a y connect between the pre out and main in, rca to bare wire to the amp.
Dude, bottom for days. No adjustable crossover. It’s not audiophile, I get it. But, for the sub and amp it was under $175. And I’ve had it with failing plate amps. Not audiophile, but when you hear wars the world is a ghetto, you know you’ve heard it.
Final set up, Sansui AU 717, SAE 180 eq, Fosi dac, DCM V8.0, DBX sub and amp. Party on.
Next up, AU 222, 555, 5500, 999 rack!
Yes, we keep a spool of speaker wire available. Cause we need to stay ready. And the power strip on top does look trashy, but we need to keep it where mrswakka can reach it.
I know this thread isn’t an earth shaker, but it’s cool. I’m enjoying myself.
We were going to put the AU 999 in first, but we’re not going to get it back for a while, so we’re working around it. Put the au 5500 in temporarily and have it hooked up to the DCM tf1000s. Big sound! I don’t have all the right descriptive words usually used. I’m not wired that way I guess. But it sounds amazing! Amazing is a good description word.
What’s fun, is because of the hardwired data splitter I’m using between the dac and the amps, I can listen to two amps playing at the same time. So I’m listening to the au 222 on the 3d acoustic 3d6 and the 3d10 sub, and the AU5500 on the Dcm tf 1000s.
Articulate 3d acoustic, ass kicking tf 1000s. Sweet 222, grab your throat 5500.
The sound stage extends well past the physical position of the speakers. Mother love bone never sounded like this before.
Again, not audiophile. I understand. I get it. This weekend we’ll be putting the au 555 in the second row. It will be the Trey 2 on the 3d acoustics, the 555, 5500 and the 999 on the KLH model ones, the Dcm tf 1000s and the Dcm tf v10.0s. And I’ll be trying all the different combinations! Audiophile? I don’t know, but damn, it sure is fun! The bottom of the 3d acoustics sub backing up the bass of the 1000s. Curious about what the 10s will sound like with the 3d sub.
The box on the top of the model one has a H&K Model 8 quad 8track player. Bought it from an extremely cool Ak member. We don’t really have the room for it quad system, but I thought it would be fun to hook the front output to the 222 and the rears to the 555 and play “flat” quad. I really didn’t want to see the Model 8 get trashed. It was a great player in the day. Still is. Had it serviced. Bought a reconditioned quad copy of journey to the center of the earth 8 track.Again, audiophile? Unknown. Fun? Oh hell yeah dude!
