Capitol C
Well-Known Member
I received a 3D printer as a present from my family and decided to learn how to use it by making a spare TP 68 head shell for my Thorens TD318 MKII turntable which has the TP28 tonearm. This head shell apparently also fits some other tone arms, see http://www.theanalogdept.com/thorens_tonearms.htm. After a good amount of learning, I’ve got a design that I’ve been using which works well.
In two of the pictures I show comparisons between the original and the copy. A third picture is taken from an angle, and a fourth shows the copy on the tonearm. I made some dimensions thicker for strength and rigidity, but the key dimensions are the same, in particular the angle between the tonearm and the cartridge. The head shell is 100% density PLA. As is typical for 3D printing, lines show in the finished object.
As far as I can tell, the only disadvantage is the visible lines. You can find metal TP 68 head shells on line, but they are rare and often not cheap.
I'd welcome feedback on this and the general question of 3D printed parts, also whether you think there is a market for this, or if most audiophiles would prefer original parts?
