4 ohm speakers
TRUE!! I followed up with calls to Denon and Yamaha customer service. Both stated that if you choose 4 ohm in the impedance section, the unit engages a protection feature that will limit the current draw. So while the manuals for both state that you can use 4 ohm speakers, the switch setting is a dead giveaway that the unit handles 4 ohm speakers by limiting the current. Yamaha does this explicitly by recommending 4 ohm speakers be set to 6. Denon does it by setting the option to 4 but in the end, all you are doing is engaging a protection circuit.
Yamaha went further and stated that with 4 ohm speakers, it was fine to leave the impedance setting at 8 and as long as you don't turn the wick up to where your ears are bleeding, the unit will not be harmed. As in a previous post, heat is your guide. The AVR won't blow up if you put a 4 ohm speaker in the same room.
My question, then, is whether clipping is occurring at some point with this sort of system. If so, then the real answer is: if you have 4 ohm speakers and want to attach to an AVR, plan on using an external amp for the LCR channels.
Realistically, I don't think the people buying 4 ohm speakers are relying on their AVR to pass sound. So this is all probably a moot point.
Again, they drop the rail voltage to up available current. The lower impedances of the speakers drives up the power output. The protection circuit is a completely separate entity on the circuit board which still functions in exactly the same way. The safe operating area of the amplifier doesn't change.
It's not going to make a big difference in performance, unless you run 4 ohm speakers fairly loud in 8 ohm mode, then you power output will likely become 0. Depends on the speakers.
Please expand on how lowering the supply voltage "ups available current". I'm OK with math.
