On the 400 I've been working on for Doug (rogerfederer), I have a problem with the eye-tube. Closure is extremely weak. Serial is 48751F
EM-84A that came with it is very faded and shows less than 45 on the emissions tester (40 is in the replace area). MPX-65 has 3 very good reading 12ax7's with fairly matched sections (by gm.) Emissions on all 3 is in the MID GOOD band. (about 75 on scale on both the EICO 625 and the Philco 9100.)
MONO closure is about 5/16" from the end on both sides. And that is with a very strong signal on air signal or from the SG-165. I also checked it for separation and get a little over -30db on both channels. Audibly the separation is very good on FM.
When shifting to STEREO the eye-tube pulls back to NO BAND AT ALL or the smallest bare line on the edges.
I put a Brand new NOS MAZDA EM-87 in it and the response is practically the same. I changed the 470K resistor on the socket to a 1megohm and no change. For shits and giggles I lifted the 1.8megohm resistor and the MONO Response is now about 1/3 to 1/2 a bar. I tried a 1.0 megohm resistor and got a miniscule increase in MONO RESPONSE but the STEREO response is not more than the edge lit. I then tried a 470K and just a little more. I don't really want to go lower as the underlying problem may be alignment as my test gear isn't calibrated. I did set another tuner next to it and could match station for station just on the oscillators nulling each other out.
Then I put a brand new 6FU6 EI Brand tube, along with the circuit changes for it, and response was worse, so the EM-87 and it's changes were put back in.
I rechecked and tweaked the 10.7 with the SG-165 and VTVM to get max voltage on each stage per manual, and checked the dial alignment and peaked that also (using the procedure Dave outlined for 400's vs zeroing the indicator pin at zero.
This tuner on a "T" dipole hung on the wall picks up most every station in the DC and Baltimore area with no problems other than the attendant overlaps from being a wide band tuner and the stations being right on top of each other. All stations are from 10 to 55 miles away. and all sound very good even in stereo, but the eye-tube only responds to MONO and only with the strongest signals. NO RESPONSE in STEREO.
I swapped another MPX-65 into it and MONO response stayed the same, but STEREO response barely made 1/4" bar's. I pulled it back out and put the original back in as I couldn't see keeping it in there for a bare minimum response. Plus I didn't know how far out of alignment this MPX was.
So the question is, is there a problem in the tuner on this 400, or is it mostly all in the MPX. Both have had C214, c221, c222, R222, r223 replaced. Also C210. R222 & R223 were changed from 22K to 16K. Mono De-Emphasis resistor (R-28) was changed from 47K to 41.2K.
I'm thinking that the multiplex is out of sorts and I'll get it aligned and then swap it in to the 400. I'll need to check some resistors in the main chassis also. Specifically, R21,22, 23, and C33 & C34.
Doug has the 400 now and seems to be very happy with it. I don't know how much FM he listens to but the way this 400 is acting I'm not happy with it in it's present condition with the eye-tube response.
