Newbie here so please be gentle. Have a Sansui 4000 and based off serial number built sometime in 1970. Through hooking up to other speakers can confirm the 4000 is sending constant and consistent static feedback to the speakers, through all 3 speaker outputs (no audbile difference between outputs), even when the volume is at 0.
In comparing the feedback between my JBLs and my Klipsch KG 4's, the feedback is far more pronounced on the KG4 but sill present on the JBLs, albeit feint. So it seems to be high end feedback only if that helps in pointing me in the right direction.
I assume the issue is before the L and R speaker outputs as the sound is identical out of all 3 outputs. The sound does get louder with volume and with music consisting of clean vocals or piano it gives an almost raspy sound to things.
I do hear a light pop when the power is turned on. The buzzing/hissing is then constant from that point forward.
Thank you for your time
