28Hz
Hi everyone,
I’m working on a project based around an Altec Voice of the Theatre system, and I’d really like to hear from people who have actually lived with this combination, rather than simply repeating the published specifications.
The system I currently have is:
The ultimate goal is not maximum SPL, nor is it to create a museum-correct restoration.
I’m trying to build a system where the loudspeaker eventually disappears and the recording itself becomes the event.
STAGE. DEPTH. EMOTION.
Width and height of the soundstage.
Depth behind the loudspeakers.
Layering of instruments.
Realistic scale.
And ultimately that moment when you stop listening to the equipment and simply listen to the music.
The 421-8H Series II
This is the part I’m particularly interested in.
I understand that the 421-8H was used in various VOT/SR applications and that there are many different opinions about how it should be used.
For those who have actually used a 421-8H or 421-8H Series II in a VOT/A7-type cabinet:
I’m also interested in the real-world lower limit of the 511B / 807 combination.
The system will be actively crossed and time/phase aligned using measurement rather than simply choosing a “classic” Altec crossover frequency.
So I’m particularly interested in experiences with:
A measurement is useful to me because it helps explain what I hear.
And perhaps the most important question...
For those of you who have spent years with VOT/A7 systems:
What change made the biggest difference to the emotional experience of the music?
Not the biggest change on a frequency-response graph.
Not the change that made the system louder.
I mean the change that made you sit back and think:
“Damn... I’ve never heard this recording like this before.”
Did it come from:
If you were starting again with a 421-8H / 511B / 807 system today, what would you do differently?
I’m very interested in both successful modifications and failures.
In fact, the failures may be even more useful.
If you have measurements, photos, old crossover designs, cabinet information or simply 10+ years of experience with these systems, please share it.
I’m trying to separate:
“I think...”
from
“I tried it...”
from
“I measured it...”
and ultimately:
“I lived with it for years, and this is what actually mattered.”
Thanks in advance.
28Hz
- Altec VOT / A7-type bass cabinet
- Altec 421-8H Series II
- Altec 511B horn
- Altec 807-8A compression driver
- Active DSP crossover rather than the original passive network
Realistic scale.
- What frequency range did you find worked best in practice?
- At what frequency did you normally cross from the 421 to a 511B?
- Have you tried several crossover points — for example 400, 500, 600, 700, 800 Hz or higher?
- What happened sonically when you moved the crossover point?
- Did you find that the 421 became noticeably less convincing, congested or distorted below a certain frequency?
- Did you ever measure the 421 in your actual cabinet? If so, I would be very interested in seeing the measurements.
- Did you use EQ on the 421? If yes, how much and over what frequency range?
- Did you ever use a separate low-frequency section below the 421?
- What crossover frequency did you find gave the best combination of smoothness, dynamics and low distortion?
- Did you prefer around 500 Hz, 600–700 Hz, 800 Hz, or higher?
- Which diaphragm did you use in the 807-8A?
- Did you ever compare the 807-8A directly with an 808, 802 or 806 on a 511B?
- acoustic crossover slopes
- phase alignment
- time alignment
- EQ
- driver protection
- distortion
- and what actually sounded better after the measurements were taken
Did it come from:
- crossover frequency?
- cabinet bracing?
- damping?
- driver selection?
- alignment?
- room treatment?
- subwoofer integration?
- EQ?
- removing the passive crossover?
- something completely unexpected?
“I think...”
from
“I tried it...”
from
“I measured it...”
and ultimately:
Thanks in advance.
28Hz
