jd3rdcoast
Been fighting with this 4230 trying to get the FM to output Stereo mode. Pretty typical symptoms, FM output is only in mono; Stereo beacon is good. Signal Strength Meter (SSM) stays to left. Very little Tuning meter movement. Mute button cuts the output. Seems my primary issue is no DC voltage change at the bases of H110/H111 or H112 for muting or auto-stereo operation. And very little voltage at J109 (490mV) to operate the SSM. No voltage at junction of rectifier diodes H121/H122 (check good) coming off of L108. H109-C == 14v.
I tested H103-H109 found H106 bad (see below).
Touched up a couple solder joints that were suspect. Checked the caps in circuit with an Atlas ESR70 but I may need to pull a couple that couldn't be read properly.
I cleaned the all the switch contacts with tiny cleaning swabs and Deoxit D5.
Rebuilt both amps and re-capped P800. Only found one bad 3300uf coupling cap. Several caps looked like had outgassed some but still measured good.
H114:
Pin-1 = 2.8v
Pin-2 = 0.0v w/no change w/tuning vs 0v (1.7)
Pin-3 = 0v
Pin-4 = 8.7v w/no change w/tuning vs 9.1 (10.8)
Pin-5 = 1.7v
Pin-6 = 7.2v vs (4.2v)
Pin-7 = 1.7v
Pin-8 = 7.1v vs (4.4v)
Pin-9 = 12.9v vs (9.6v)
Pin-10 = 10.1v vs (6.8v)
Pin-11 = 10.1v vs (6.8v)
Pin-12 = 3.9v
Pin-13 = 3.9v
Pin-14 = 12.6v vs (9.5v)
Pin-15 = 1.8v w/no change w/tuning vs 1.7 (1.4)
I did find one bad transistor H106 B-E is open. I moved a 2SC930C from H105 location to the H106 location and put a KSC1845 in the H105 location. My thinking was H106 seems to feed base of H109 which in turn provides DC from rectified Sub IF signal to base of H110 thru R153 for muting and Auto-Stereo and Signal Strength Meter operation. But that setup did not yield and change in operation of either of those functions.
Couple other Transistors that don't match the spec'd H103-H109 2SC930C called for in SM are:
H104 = 2SC380; TO92 pkg. Viable sub, ft 125 MHz
H107 = 2SC772B; R145 pkg. Viable sub per specs. ft 150-300 MHz in different datasheets.
H108 = 2SC829C; TO92 pkg. Viable sub. but ft only 75 MHz
H105 - KSC1845; TO92 pkg. My sub but only 50 MHz ft so may be a bad choice.
So, it seems this tuner was worked on at some point with the TO92 subs installed.
I have 10 Sanyo 2SC930's on order from BDent. Should be here in a few days. I figured I'd use them to replace the odd transistors one at a time to see if can get my DC voltage out of H109 to trigger H110 and so on. I do have a scope if need to measure any signals anyone might suggest. Any other suggestions or comments would be much appreciated. These FM Muting and Auto-Stereo circuits are the bane of my existence!!! But I am determined to not let this one beat me, hopefully with some input from some of you.
Attached is copy of circuit with values I measured:
edit - this is the schematic from 105 Tuner which is identical board part number and circuit as 4230 P100 board. This has voltages on it where the one in 4230 manual does not. So they should be close but possibly not exactly the same.
H114:
Pin-1 = 2.8v
Pin-3 = 0v
Pin-5 = 1.7v
Pin-7 = 1.7v
Pin-12 = 3.9v
Pin-13 = 3.9v
