4ohm 90Watt speakers to 8ohm AMP JVC AX-R350.
freeman2020, if your integrated amp was rated to drive a 4 ohm load the back panel would have a similar label to these two examples. Both are a similar vintage to yours and one is a JVC. Both prove charles and bowtie are incorrect.
Looks exactly like the AX-R441 I just got. It specs the same and looks the same. I had the same one you just bought for 40 years. Cranked up all the time and never faulted with 4 ohm speakers. Back right corner will get hot enough you can''t hold your hand on it. Lost mine in a house fire, so I bought what I thought was the same one, picked it up and it isn't. Also bought the same speakers I had. VERY hard to find. The R441 trips just when its really starting to get good. The R350 like you just bought that I had never missed a beat. Regardless of what the back says, I could of swore the manual that came with it gave a 4 ohm rating. Could be because of the way it handles A and B speakers. If I remember right you could push B speakers on without any hooked up and A still would play. The R441 wont play A if B is pushed on with no speakers attached.
