5 pf ceramic cap replacement
now click "thru hole" and "in stock" and you are left with the list of the same 26 caps that i linked above. ;)
But you don't need to use "thru hole" ! buy a chip cap, cut off the leads of the old one and solder to the chip!
Or if you removed the old one's leads, just use some solid wire of the proper length.
Or solder them on the foil side without leads (if long enough).
. I've seen "gimmick" caps in a number of pre-war radios up in the tuner section to fine-tune some value or to couple oscillators to the mixer. Not sure if they just didn't make those low value caps or if it was simply more cost-effective to make them to value as needed, but it certainly works.
