Anyone know where to get replacements for these older style caps? I've been searching Mouser, Digikey, Allied, Michael Percy catalogs and can't seem to find them.
Caps in question are the main filter caps in a Philips High Fidelity Labs 7951 receiver. The cap markings follow:
Nichicon
5600uF 50wv
Ear Negative
270099-45
85 C
7750 (stamped sometime after manufacture)
From the photo attached it appears that the 4 "outer ring" pins are all connected so that must be what's meant by Ear Negative. Then there's one pin offset towards the center of the cap.
Some of the data sheets show there are 5 pin options, but it appears that 2 of the 5 are positive, the remaining 3 negative. They'd all be special order. Could this turn into having to cut the can open and stuffing the can with a newer 2-lead cap soldered to the existing pinout?
John
Nichicon
5600uF 50wv
Ear Negative
270099-45
85 C
John
