50ohm headphones (Fostex T50rp)...is that an issue
lorriman
50ohm headphones (Fostex T50rp)...is that an issue?
I've understood that HP sockets on integrated amps/receivers do no favours for headphones rated at less than 120 ohms: that I would be better off getting a (cheap?) cmoy. My phones require a lot of power but have lowish ohms, at 50. However they are orthos and I was wondering if that might compensate in some way.
Or perhaps there are integrateds or receivers that work well as HP amps and have a lower spec for headphone ohmage? I would love some recomendations. I'm in the UK so my choice of quality amps stretches to rotel, kenwood, Denon and pioneer (not forgetting yamaha and sony; I just don't hear much of them). There aren't any Marantz's or Sansui's here.
As a third possibility: might I be able to rig up some kind of gadget to adjust the HP socket to make it more friendly to my orthos? Or perhaps I could dissemble the HP socket and put some resisters in to it? I'm handy with a solder but know absolutely nothing about electronics.
50 ohms should not be an issue for vintage receivers (e,g, 1980 and earlier) and probably newer ones too. The only amps I know that have trouble with low impedance cans are tube based and output transformerless.
The problem with using receivers is that they have a high output impedance, that would most likely be many times as high as the headphones impedance, this could cause dampening issues.
Thanks for the replies. I did understand that they would work but what I'm concerned with is whether there would be a significant loss of quality.
Are you mentioning receivers particularly as opposed to integrated amps? Would I be better avoiding receivers?
The T50Rp's are one of my favorite headphones once modified but they do like a little power. They work extremely well with vintage receivers and integrated amplifiers that operate the headphone jack from the actual amplifier itself. They will sound like ass from a lot of more modern headphone jacks that use a very basic opamp setup.
FYI: Most older integrated amps and receivers simply fed the headphone jack directly from the speaker outputs, via a few 50 to 100 ohm padding resistors.
Op-Amps at the time thankfully weren't even a consideration or option.
Thanks for that BmWr75, but It's just too long and liable not to answer my question (I've already tried googling head-fi for this issue).
Vaughn, that's great to know.
Granted that is a long thread, sorry about that.
Bottom-line: buy a 70s vintage receiver or integrated that is in good shape (recapped preferably) and you should be good to go.
Alternatively, you can buy a solid state Matrix m-stage headphone amp for $270 including shipping on Amazon.com (from TAM Audio, the reliable Matrix shipper in China) and be set also.
Thanks for the advice, guys.
Any word on a minimum power requirement for the Fostex? For example would it be fine to go for a cheapo 20W Rotel amp? I don't expect to get one of those; simply sounding out the limit.
You already got our answer here:
http://www.head-fi.org/t/537704/calling-all-vintage-integrated-receiver-owners/2835#post_7795369
At the risk of starting to beat a dead horse........cheap, low power receivers made after the early 1980s are generally not going to be optimum for headphones.
If conserving electricity is really a concern and $100 is within the budget, check this out. It is the top rated portable amp on Head-Fi.org:
http://www.head-fi.org/products/electric-avenues-pa2v2
http://www.electric-avenues.com/amplifiers.html
Sure, but opinions vary. Of course it doesn't help if all the same people are in both forums; but I doubt that's true of everyone.
I'm assuming that this isn't true of Rotels which is what I'm most likely to get; or perhaps I should say 'cheaper' Rotel. I have the impression that I won't be fobbed off with an opamp if I get a Rotel, even a cheap one. The issue for me of very old kit, that you mention, is the need to get a service. I am actually handy with a solder but warnings of "unless you know exactly what you are doing don't due to high voltages" have rather put me off the idea replacing all their caps myself. I don't wish to acquire a harp just yet. But I can't really afford a service.
I love stuff like that. I can't justify it however, unless it really is impossible to get lower power integrated/receivers. Right now I am assuming that a 30W amp uses 30 watts of power, which is less than a light bulb. The reason I mention it is because that assumption may be completely wrong and infact unbeknown to me I may be burning 500 watts, which is way too much. That would come to 7p an hour which over a year would be £50 instantly justifying that headphone amp.
Thanks for the great advice.
50 ohm headphones are a bit low for a CMoy especially if they are low efficiency. The chip will current limit and distort at relatively low volume. Most older amps would have been designed to drive 8 ohm headphones so, on paper, 50 ohm phones shouldn't be a problem however they may not provide much drive.
