Rodzilla
...hmmm well this is interesting.
i had been wanting to upgrade the op amps in my ancient Yamaha DA2X dac...this dac was a pro studio piece circa early 90's,so while it is older digital,it's also fully balanced input to output[two dacs in one box really] it has a very high quality build,it's chock full of name brand audiophile grade caps etc.Yamaha pulled out most of the stops on this,but then used a slew of cheap as dirt 5532 op amps for the outputs...now being balanced only when i say "a slew" there were actually eight JRC 5532's in this output stage,and that doesn't include the four JRC 2114's before them[i assume these are the analog filters]
now the interesting thing is that in reading around the net,a lot of pro audio types actually seem to like the 5532,apparently the consensus is that in studio work it doesn't muddy up the sound as much as many others when there are multiple layers of them all operating one on top of the other...so i guess while it's not perfect,it is thought to be fairly neutral...
so anyway on to the curious part,i wanted to do this right..so i got a good deal on some sockets and chips from an ebay seller,so that i could cover the 8 5532 positions with sockets and also have a supply of new 5532's to start with as a baseline before trying other "upgrades",i had suspected the originals wouldn't all survive removal to be reused...which of course they didn't
so the only post surgery differences amount too..the new sockets and the new chips,which were texas instruments branded 5532's vs the old JRC branded originals...now i had also read that being a basic commodity type part not all 5532's were created equal,they all interchange and meet spec,but there are differences between makers...most pointed to the Ti parts as top of the heap....
and now the whole point of this long story...they truly are better,it's actually a bit shocking.the improvement is not day and night,but it's clearly better...more details and cleaner overall,better depth etc etc...they're slightly better all around,and it should be said...the Ti 5532's I'm using are NOT the low noise "audio" NE5532AP versions but the bog standard NE5532P...but they still clearly blow away the low noise graded JRC's
moral of the story...if you're looking to swap out one of these common as dirt 5532's and it also happens to be a common as dirt JRC one...the Ti version will swap right in with NO other changes needed to the circuit and they sound better...not so much different,but clearly cleaner and better...they cost all of about a buck each at full retail..and believe me,you've never gotten better audio value for a dollar...
now i need to order me some "a" versions,and figure out what to replace the JRC 2114's with
And then it could be worse than with a 5532, which is at least unity gain stable. Try a 5534 as a voltage follower and you're in for a surprise
