chetgallery
Member
Had a 5AR4 blow on a Pilot 240 after about 30 hours after a complete restoration. I normally knock the line voltage down due to the higher line voltages these days. On this one I used a CL90 thermistor and a 15 ohm 60 watt resistor. I would like to hear the voices of experience on my voltages. Pin 4 and pin 6 both have 235 volts ac and that produces 270 volts dc out. Is this voltage too small and has it expedited the 5AR4’s life? There are no minimum voltages that I can find. Hope to get a better insight on this. I have restored many tube amps with the voltage knocked way down without any issues.
