As has been explained already, different rectifiers drop slightly different voltages changing the B+ voltage and they can also draw different current, from 2A to 4A, from the power transformer. So the first thing to do is to establish the specifications on the power transformer. If that's not possible then you can guess from the original equipment. Does the manufacturer specify a GZ34? Then expect that the power transformer supplies 2A. Does the original equipment come with a 5U4? Then you are good to go @ 3A.
The power transformer on my present amps can provide up to 4A of heater current so I did a taste test with a wide range of rectifiers. The results were, in order of preference, IN MY AMPS: 5V3A/5AU4, GZ34, 5U4, GZ37, 5R4, 5V4.
While the 5V3A/5AU4 were clearly the best, there was much more difference between the GZ34 and those that followed. In other words, IN MY AMPS, I preferred the 5V3A/5AU4, and could live with the GZ34, the rest were clearly inferior.
So first determine the specs of the power transformer and then do your own taste test with those rectifiers that are appropriate to the equipment.
BTW: the 5V3A/5AU4 generally are priced about $10 each for NOS. The Mullard GZ34 looks like a toy next to it!
