tweedsmith
It's been a long journey with this 6060, mostly centered around the 2647 Driver board. After replacing the 2SA726 Transistors and a recap of that board, I get clear sound on all inputs from both channels and the bias on both sides adjusts to in spec per the service manual. I'm not sure if the 6060 has a way to check/adjust the offset (and if fact when I've tried to research it seems I see bias and offset used in the wrong context or interchangably - at least as I understand it from the service manual for the bias adjustment)
Everything sounds good in my testing, but I'm wondering about the fact that the heat sink is too hot to touch for more than a second or two, and with the lid on, the metal grate is pretty hot as well.
My main questions are:
- Is it normal to run that hot?
- If not, how can I start troubleshooting the source?
- What is the best way to measure the DC offset
- If the DC offset is off, is there a way to adjust that or replace components to improve the reading?
