I bet there is a section on "Buran" that is reserved for tubes.![]()
Notice how these tubes have pointed tips? A characteristic of this era mil spec Soviet 9-pin mini tubes. They mate well with their very well made mil spec sockets. The combination will have positive contact for a long time.
Was it GAZ-69 (older) or UAZ-469? Later was still in production when I left the country in 1993 and I think had some modifications produced for civilian use.Some years back someone was going to purchase and import surplus Russian versions of the Jeep. Being a Jeep guy I was exited. I've read they will run on almost anything you pour down the fuel tank thats flammable. They also looked to be over built. But the person was stopped from importing them do to smog laws in the US.
If I remember right they were military surplus being sold off after the wall came down. I don't know how old they were though. I still wanted one. They can't be to much rougher to ride in than a moddified jeep like mine. When I installed the lifted suspension, I used so called "soft ride" springs. The first couple coils are supposed to be softer than the rest of the spring. But I can't tell the difference.Was it GAZ-69 (older) or UAZ-469? Later was still in production when I left the country in 1993 and I think had some modifications produced for civilian use.
I think, originally they both were modified post-war Willis spin-offs. Good, dependable trucks but if you spend a day in one's tent you will be sore the next day almost like after the good workout. They are ROUGH! I rode in the tent of GAZ-66 for about 2 weeks at 6 hrs a day. You get used to it.
6H8C tubes have a different logo.
Please share your thoughts on them.
I ran some comparison tests. Please note that I don't have known NOS American-made 6SN7 tubes to compare to. I ran one Tung-Sol reissue sample and one Russian 6H8C through my Hickok 533 for Gm and then, both of those through AF position in the amp and took measurements.I found the 6H8C to be too hot, meaning they have too much gain for a 6SN7.
Those Soviet Jeeps are likely rougher still. No coil springs there - leaf springs, front and rear.If I remember right they were military surplus being sold off after the wall came down. I don't know how old they were though. I still wanted one. They can't be to much rougher to ride in than a moddified jeep like mine. When I installed the lifted suspension, I used so called "soft ride" springs. The first couple coils are supposed to be softer than the rest of the spring. But I can't tell the difference.
It's still a rough ride. Nothing like the new Jeeps being used to get groceries.![]()
With feedback or OL?I find those 6H8C tubes to sound quite nice.
I haven't heard this about the 6N14P-EV. To the best of my knowledge, they were all manufactured at the Reflektor plant in Saratov, Russia.Some people claim the earlier production 6P14P-EV is better than the later ones from 80/90s, is there any truth in this?
About the only NOS Russian tubes that were better are the St Petersburg-made Svetlana output tubes. Their 6550C was much better than any of today's Russian issues, including the Saratov-made 6550. I could run those 6550Cs in the amps that had OEM Tung-Sols (USA) or GEs — similar electrical settings.Has anyone ever said that a more available tube is superior to a less available one? I think scarcity must be part of the magic. Maybe I should buy cargo container loads of some dirt cheap tubes so I can start the rumor that they are the ultimate vacuum tube and slowly trickle them out to fund the purchase of a private island somewhere.
I remember them making one amp I tried them on sound a little softer and more relaxed than with Tung Sol reissues. Not saying that Tung Sols are bad, they sound great in VTA SP14.I have a Reflector 6H8C I'll be using in the EL84 SE amp I'm building.
I used them in another amp and they sound pretty good.
The 6H8C sounded better than the Tung Sol 6SN7 in my VTA ST-70.
