Ok, on my stereo SE 6L6 project, I think I have the power supply and output stage all squared away. Now I'm on to the driver stage. My initial plan is to use a single 6SL7, and drive each 6L6 with one half of the 6SL7. There will be a volume pot between the 6SL7 and the input jacks, which will be fed with garden variety consumer line-level signals. From my output stage load line, it looks like I need ~8.5Vrms to drive the output to full power.
On paper, the power supply node feeding the driver stage is at 251V.
Because I want to experiment with NFB, I want to maximize the gain (because it's eventually going to be reduced by the feedback loop), and I obviously want to minimize the distortion generated by the driver stage. To minimize the distortion, I want to keep the plate curves as evenly spaced as possible along my load line. It looks like I can do that by using a fairly small plate load and center-biasing, but then the gain of the stage is significantly reduced. But it also looks like I can do this with a pretty large plate load and biasing a little hotter than center.
The load line I came up with for the latter scenario is based on a 510K plate load, which gives me 0.5mA for the 0V end of the load line, and 0.3mA idle current for a -1.5V bias point. On paper, the gain is 59 (35dB) for a fully-bypassed cathode. I went back to the 6SL7 data sheet and the example circuits table does give an example for a 510K plate load, so the idea doesn't seem absurd on it's face, but I've never personally seen a triode gain stage with a plate load any larger than 220K (then again, I haven't been at this very long).
So, my question for you all -- am I off the rails here, or does my design seem reasonable?
