Eric Brandon
I have an Elekit TU-8200DX amp which takes 12AU7 driver tubes, and an Elekit TU-8600 amp which takes both 12AX7 and 12AU7 driver tubes.
I was hoping to try 6SN7 tubes instead of the 12AU7 using this adpater https://www.ebay.com/itm/1-6SN7-To-...Amp-Convert-Socket-Adapter-6-3V-/283133429197
I was also hoping to try 6CG7/6FQ7 tubes instead of 12AU7 using this adapter https://www.ebay.com/itm/1pc-gold-p...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Finally, I was planning to try using a 6SL7 tube instead of the 12AX7 using the same adapter I would use for 6SN7 in a 12AU7 socket.
Is any of this a bad idea? Don't want to damage my amp.
Thanks!
Thanks!
