Thank you!That driver stage has enough output to drive the KT88s right out of their sockets — and rather easily so! A classic Williamson design……..
Dave
Dave
300B requires significantly more voltage and current to drive than KT88, but the 6SN7 is a very common choice for that.
Keep in mind that a 6SN7 is two triodes in one bottle, so one tube could be a three-stage design, and the two-tube setup could have sections paralleled and also be a three-stage design. The answer really becomes "it depends", depending on the circuit and the goals. Generally speaking, common advice seems to be that to sound best, 300Bs and other power triodes need to be adequately driven so not somewhere to flirt with the minimum.
So, the wiper remains unconnected?I'd like to suggest a modification to the bias arrangement. See attached. This would let it fail safe in the event of a pot failure.
Yes, a fail-safe design is always better than a design where a single failure initiates a destructive chain reaction!no, the drawing indicates it wired as a variable resistor, not a potentiometer. The wiper is connected to one end of the resistance track. Different schematic symbol for a VR vs a pot. If the wiper lifted, you'd get minimum voltage drop which = max negative grid supply. Tube stops conducting vs starts to cook itself to death.
this also should have a fixed resistor between the end of the variable resistor and ground to limit the adjustment range. As-drawn it could be adjusted to give 0 grid volts which you'd never want or need. Normally you'd want to design it knowing your expected bias voltage and have that be the output voltage with the pot set at approximately mid-travel. Set up the resistors on either end of the pot so the adjustment range is within some sane amount, maybe +/- 10% of the target grid voltage. The more range the pot has, the more touchy it gets so there is always a compromise of adjustment range vs ease of adjustment.
can also get this done with a resistor from the wiper to the bias supply end of the pot to provide a path to negative supply. Both methods work fine, but having almost lost tubes because of pots that decided to behave poorly I'm not in love with having to rely on them not getting flaky.
Thank you so much for the visual input. Makes sense and I will absolutely implement that measure. Do you or anyone else have a suggestion on where to order good components that won't break the bank? This will be my first build, so I'm stumbling through the trees right now.....I'd like to suggest a modification to the bias arrangement. See attached. This would let it fail safe in the event of a pot failure.
As for the 300b, a quick and dirty way of estimating required drive voltage is to look at the grid bias. If it needs -45 volts, that tube needs pretty darn close to 45 volts peak to drive to full power. A push-pull amp would need double that grid to grid.
Antique Electronic SupplyThank you so much for the visual input. Makes sense and I will absolutely implement that measure. Do you or anyone else have a suggestion on where to order good components that won't break the bank? This will be my first build, so I'm stumbling through the trees right now.....
Things like a good volume pot, tag strips, octal sockets, etc.......
Love that tubeAnyone have any comments on Tung-Sol 6SN7GTB's driving KT88's in PP?
Is it enough to drive the KT88's to full?
And can someone direct me to a good source on learning about how to cascade a driver stage?
This is what I'm looking at putting together:
Yes, I have a tektronix 2213 oscilloscope. Been looking for a signal generator at some ham swaps; no luck yet.So, if I understand correctly, you're going to build this PP KT88 Williamson design? A few suggestions:
1) A Williamson is my favorite type of PP amplifier because of the naturalness of the sound. You'll pry my DIY Williamsons out of my cold, dead hands. ;-) But it took a fair bit of learning to get there.
2) Williamson amplifiers are challenging to build. Because of the number of frequency poles in this amp, they can be difficult to stabilize.
3) Because of the amount of feedback employed in a typical Williamson, the output transformer is critical. It must have enough bandwidth to tolerate the amount of feedback employed. You can't drop in any old output transformer and expect the amp to perform properly. It might even oscillate and potentially damage your speakers.
This being your first build, I'd ask the following questions, because a PP feedback amp, and especially a Williamson, can be a challenge:
Do you have any test equipment, like an oscilloscope and a signal generator? Nothing fancy, just the basics. An entry level USB Picoscope is not expensive and is a *very* handy tool.
Also, do you really need 60wpc? What speakers are you driving? I ask because a 25wpc cathode-bias Williamson is not only a nicer-sounding amp, IMO, it is also easier to build from known schematics. But a 60wpc Williamson like the early Dynaco designs is also quite nice.
Before you spend a dime on parts and ***especially*** before you buy output transformers, it would be a very good idea to find a schematic that specifies readily-available components and has been carefully designed around those components.
There are folks here and at diyaudio who have designed good feedback amplifier around commonly-available transformers from Hammond, Edcor and other suppliers.
If you have some test equipment and want to build from "scratch," that's great and I know a lot of folks here would be willing to help and would be interested in your results.
My guess is that a Hammond 1650N would be your best bet for this circuit, and you could probably find a tested schematic using it. The Hammonds are variable, but the 1650 series seems to be pretty well-regarded.
I got really interested in Williamsons a few years ago but had built NOTHING more than a simple SE 300B amp. I have some really terrific sounding amps now and I owe that to the incredibly generous folks in this group.
