Kegger
R.I.P. 1/12/1966 - 6/1/2017
I'm wondering others use of the 6V6 an what is the consensus of "pushing" them? (vintage an new)
I know quite a few guitar amps run the voltage up there on them but not sure of there dissipation.
Here is my scenario:
I built a single ended amp, actually my "tube tester amp" running 7AC pinout tubes triode strapped
with a octal socket for driver pinned out to the 8BD (6SN7 type) but I also have an adaptor to run
a 9A pinout (12AT7 type) in that spot to "test" an listen to any of those types for noise or whatnot.
(all pinouts are top side monitorable)
Outputs are cathode biased, running 5V4 rectifier I get roughly 340v B+ which is my center voltage,
going to 5AR4 obviously is higher and the 5Y3 being lower plus the rest that pinout in the same slot.
(For the 6V6)
With the 5V4 I get roughly 320v plate to cathode at 46.8ma, for plate dissipation of just under 15w.
With using 5Y3 I get roughly 289v plate to cathode at 42.6ma, for plate dissipation of just over 12w.
(I think I'm alright with this setup but the other I believe is pushing it..?)
I am trying to run a "universal" cathode resistor(470 ohm), by changing rectifiers I can get different
voltages and the usual say KT88/6550's draws 60ma each, where your 6L6 plus EL34 draw just over
50ma, with everything between there running just fine, it's the 6V6 that brings up the bottom an by
running them kinda hot makes others fall in line pretty well but how hot to think I can get away with.:scratch2:
(For the 6V6)
