ttbccw
Here is an interesting question:
A little while ago I restored a Newcomb D-12 amp. It sounds good, performs well...however...I've been using it on and off in a dedicated Mono 78/45 setup and I noticed the power transformer will get hot after about an hour of listening. I'm guessing the 6V6's are biased a little high. Here's why.
After 1 hour the power transformer gets pretty hot.
Incoming line voltage is 117acv to 120acv
The measured plate voltage is 344v, and according the schematic it should be more like 325v-330v
If I look at the tube data sheet for PP 6V6 it says max plate voltage of 285v.
I measured the resistance between pin 3 of the 6V6 & pin 8 of the 5Y3, the voltage drop, then plate current.
Plate dissipation is about 15.5watts...a little high. (344v vs 330v = 4.2% high.)
Should I change the bias on these? Both the SAM's and the scematic on the bottom of the unit have 325-330v on the plates...it just seems high? No?
