Hey all, so I have what seems to be a simple issue, or so I thought it was... I have a 7070 here that makes a fairly loud pop when the relay closes, what I noticed was that if I disconnect the normally closed pins which have 12 or so V from the muting circuit the pop goes away, the muting circuit does seem to sort of work as I do see the transistors in it switching when I change inputs or push the phono 1/2 switch but there is a faint pop when I do that with no input. Any ideas? I'd rather not remove that 12V from the outer relay pins as I don't want to mess anything else up.
DC offset at the terminals starts at 4.5v when the relay is open and then drops to less than 20mv when the relay closes (and the outer pins rise up to 12v)
