Keeping on the original ST-70 topic I'll use a schematic for that, but your Paco is essentially the same circuit.
direct coupled meaning the plate of the pentode (pin 2) is directly connected to the grid of the triode (pin 9). The voltage at the pentode plate is the grid voltage, and thats what will set the current flow through the triode section. The screen resistor you may have seen mentioned in this case is the 1.5K resistor going to pin 3. Changing the value of that resistor will significantly affect the current flow through the pentode, and change the pentode plate voltage, which changes the triode stuff.
the voltages Tom was talking about is percent of voltage that would be measured from terminal 20 on this one. Just for ease of math, lets say its 200 volts. You'd want to see about 50 volts at the cathode (pin 8) of the triode, about 150 at the plate (pin 1). That would be 50v across the cathode resistor, 100 from plate to cathode, and another 50 across the plate resistor.
I think the supply on the ST-70 is closer to 300v but I don't feel like looking it up.
