riverrat
professional camper
OK, some semi-clueless antenna and cable questions...
I'm starting to prepare for my "decent outdoor antenna" project. Placement options are crimped somewhat by HOA and WAF issues. I'm guessing I will need about a 50' run of coax to reach my tuner, maybe a bit less.
I found a 1000' roll of the following Belden coax cable for sale locally for $20:
Belden 9116 75ohm RG6 MATV coax (also suitable for FM antennas)
#Conductor Material & Diam: 18 AWG solid bare copper covered steel, .040"
# Dielectric Material & Diameter: Gas injected foam polyethylene, .180"
# Shield type: 1st layer - Bonded duofoil, 2nd layer - 60% aluminum braid.
# Jacket Material & Diameter: Polyethylene (Black or Orange), .270"
That is about 20 times as much cable as I need, but I could perhaps unload the rest of it. So my questions are:
1. Is this nice quality coax?
2. Is there any benefit to getting "better" cable? If so, what cable would this be?
3. How easy would it be to hook up a switch box (so I can use more than one tuner) and F-connectors to the bare cable? (Presuming that I'd use the same coax into and out of the switch box.)
4. What kind of switch box do I need and who sells them?
5. Is it pretty straightforward to hook up the cable to the antenna end?
