75 Ohm FM Antenna Adaptor
lordsparky
Looking for an 75 ohm FM antenna adaptor for the back of a tuner.
First Photo: Tuner - Female about a half inch wide.
Second Photo: Adaptor - Male on tuner side. Other side, 75 ohm female to connect to 75 ohm FM antenna cable
FM Antenna Cable: 75 ohm male
Does anyone know what this is called and where I can buy one?
Thanks!
I have a slew bulk bags of PL-259 connectors from back in my HAM radio days, the quality ones where more silver content was used along with good insulating materials. Later, cheaper chinese ones came along that had cheap plated coatings and low grade plastic insulating materials. Probably fine for audio, but when it came to transmitting with any power output, the best seem trouble free in the long run. And I remember a lot of the cheap plastics melted during soldering. For adapter use, they should be fine for receive duty.
