goodolpg
Just an old fart trying to help.
I have an exterior antenna with about a 40 ft. run of 300 ohm wire.
Would 75ohm be better to use?
I figure I can use converters on both ends to make the change as there is an existing no longer used 75 ohm TV cable running in the same location.
If there is no difference then I won't bother going up on my icy snowy roof.
Thanks for any opinions.
