777a
Jason Vega
AK Subscriber
When turning up the volume past 3 it goes into protection mode. I know those could be a number if different issues but for those experienced Tech's out there, where would you look first to try and find the problem? Yes i know i should restore it, but i have yet to find an experienced technician i trust to do the job. Thanks in advance
or flipping the Loudness switch. in other words, as soon i give it some volume/power it goes into protection mode.
What speakers are you using, and are you using 2 or 4 speakers?
The protection circuit in the 777a monitors the current in the output transistors, if the protect trips then the amp is being overdriven (or the protect circuit is incorrectly adjusted or has a fault, but it seems that you are diving the amp pretty hard)
Does the amp go into protection with source connected or no signal. The 777a is one of those amps where you rarely need the volume past 11, not because it is a power monster, but because potentiometers back then werent logarithmic - so 3 o'clock likely means full power. Even without a signal, I would not be surprised if full power can trigger the protection circuit. It is a very simple system, just consisting of a thyrister with a threshold adjustment determining when DC current fed back from the output emitters are too much. As Skippy124 says, that adjustment can be too trigger happy or there is an actual fault hiding there or somewhere else triggering the protection. However - unless the loudness causes "protecting" from "normal" volumes - then I am not surprised that cranking a 50 year old amp with a simplistic protection circuit can be triggered, signal or not.
If the amp on all other account functions/sounds normally then I would not worry about it - in fact the amp is showing you that its protection is working when maxed out on power. If the switches are very dirty, especially the volume, then they could potentially produce some loud scratchyness that might find its way to a trigger happy protection circuit, this include a dirty loudness switch, so cleaning all controls is a really good idea to do first.
let me clarify. turning up the volume just a bit, way before half way point causes the amp to go into protection mode. I can play it at a low volume just fine but cannot turn the volume up much before this happens. source is cd player. Turning it off and back on resets it and it plays again just fine.
Was it loud right before protection kicks in?
Hey i know its been a few year since this thread was active, but i have the same 777a amp with the exact same issues as you are describing . i was wondering if you were ever able to figure out the cause and get it repaired? i will likely get the amp restored to Leestereo specs eventually. But for now i want to know what's causing the fault.
