8 Track player - won't play :(
stonecutter2
I've got a Realistic TR-169 8 track player deck.
I plugged it in last night for the first time in years, and it just sits on section 4, and hitting the program button doesn't make the characteristic "ka-chunk!" to change the track. It makes a muffled attempt at changing tracks, but is still stuck on 4.
Sound familiar to anyone?
I'll probably crack it open later tonight to see if I can figure it out, but thought I'd tap into the wisdom on this forum.
Thanks!
I bet that you will find that the belt is now a nasty puddle of goo. If it is, you can try turning a can of compressed air / air duster upside down and freezing the goo solid so that you can pick it off in chunks. That works sometimes.
The track changing mechanism sounds like it needs to be lubed. Very common. I have some contact cleaner/lube that I usually use on these. It frees up the old dried lube and relubricates.
Step one open the trash can lid
Step two place TR-169 in can
Step three place lid back on trash can
Step four go buy a cassette deck.
:D:D:D:D:D:D:D:D:D:D
I'm sorry I just couldn't resist.
Haha :D
:nono:
Step one: Take off TR-169 cover.
Step two: Put 8-track "capstan cleaner" in player (no tape in it)
Step three: Look at why capstan/belt on the bottom isn't turning.
Step four: Nudge the motor's spindle a little bit.
Step five: Watch the motor/capstan come back to life, and put cover back on.
Step six: Play some Bee Gee's and Abba and :D
:thmbsp:
Easy fix, thanks everyone! Just had to encourage the motor a little, I guess it got gummed up just a bit, from sitting for awhile. Might need to lubricate a couple of things, but she's alive again!
