crkeith65
Member
Let me set this post up right to begin with. I have owned this 8080DB since new. After letting it sit idle for many years because of driver board failure, I took it out to reclaim it's glory. The driver board was completely gone through along with re-capping the power supply board and 4 new output transistors I made a few repairs on the Dolby board just for the fun of it. All switches and pots were de-oxed and lubed. After weaning it off the dim bulb tester, offset and bias were set according to the manual. Everything was working fine for several days still on the work bench. The day that I was going to reassemble everything the FM became very erratic. ( separate post) I narrowed it down to a defective front end. While I had the tuner section off to remove the front end I powered the unit to check a few more things. One thing I found was a stuck contact in the relay. I removed the relay to free the contact then re-installed it. That is when the protection circuit started kicking in and out randomly. I thought that it was just because the tuner section was removed. I ordered a new relay and a salvaged front end and installed it today. Good news is that the tuner now works. Bad news is receiver stays in protection. This post is getting long so I will reply to give my latest symptoms.
