Nice job!
I am right now in the midst of wiring an 832A stereo amp. The physical cutting, painting, and bolting together of the chassis, trannies, and sockets is done. Now I must tune and wire. I went with iron I already had, so I will be using a higher B+ compared to the starting schematic found elswhere on the web. Here's what I had in the garage, so here's what I have on my chassis: 300-0-300 - 200ma PT, 8K - 8R OTs, 5H-200ma choke, 5U4GB rectifier. So it looks like my B+ will be close to yours.
I have available as preamp/drivers a bunch of the 12AU7, 12AX7, 12AY7, & 6EU7 type tubes. Have you tried anything besides the 12AT7?
I wondering if the higher B+ necessitated any changes in your schematic. I see there are two differences that I would expect - a larger cathode bias resistor 330R vs 270R, and a larger grid resistor 27K vs 4K7.
What about 330uF cap at the 12AT7 cathode, and the coupling cap and resistor - .68uF/470K vs .22uF/390K - parts on hand or tuning? I plan on doing some experimenting or tuning myself, but I thought you may be able to share some experience.
Thank you so much in advance for any advice. I'm still a noobie at this (and may always be...).
