8v 30mA bulb?
StuartB
Anyone know where I can find a miniature 8v 30mA bulb, ar suitable replacement?
This is for the Stereo light on an old Sony STR-7055 receiver.
I have been able to remove the rubber grommet that holds the bulb, so now I need a replacement. LED would be fine as well. Thanks.
If you're near Radio Shack, their 276-0017 neutral white 5mm LED might work nicely. Remember LEDs are polarity specific and you will need a limiting resistor in series. 1K ohm should reduce the brightness enough that it is not too bright for a stereo indicator.
dgwojo.com Dave will hook you up with the correct lamp.
