drbacklash
I picked up my first 9090 this past weekend and put it on the bench to check it out. It came out of protection fine and didn't sound too bad through my bench speakers. (This is where I should have stopped but you know I didn't or I wouldn't have the title above).
I have set the bias and offset on several Sansui receivers so I'm not a total rookie at this (this is my qualifier). The DC offset was too high on one channel so I adjusted both to specs (0V + or - 10mV). Since the offset was high, I had reason to suspect the bias was probably off too (oh, those damnable assumptions). The SM is for both the 8080 and the 9090 and of course the illustration for the bias adjustment is for the 8080 F-2546 board which is a little different from the 9090 board. For this adjustment, you have to pull the fuse from F07, adjust, replace the fuse, pull F08, adjust and replace that fuse. The problem is identifying F07 and F08 (the illustration is for the 8080, remember?) and the fuse number is actually covered by the fuse holders on F-2546. But by using the CB layout for F-2546 (that matches my board) on page 10 of the SM, I was able to identify the correct fuses (I think). They are the two middle fuses out of four located under the F-2436 Driver Board.
Pulled one of the fuses (yes, with the power off) and connected my DMM clips according to the instructions. Set the DMM to 200mV (target is 50mV) and turned it on. OL. Up the DMM to 4V. OL. I finally get a reading of about 65V (did a bell go off? Nope). Turned the pot to see if it would adjust down to 50mV (mistake). Tried the other Fuse with the same result. By now, the adjusting pots are no where close to where they were. Then I notice that the target is not mV but mA. The instructions list the L-CH adjustment as 50mV + or - 1mA. A typo that was not repeated for the R-CH but I missed it the first 100 times I read it.
Here's where it gets dicey. Turned the receiver off and as I was removing the DMM leads, the positive lead hit the metal case while the negative was still connected to one of the fuse holders. Sparks flew, loud noises were heard and I began to speak in unknown tongues. Apparently, my 9090, maybe not yours, holds over 55V on F-07 and F-08 even after you turn the unit off?
Replaced all the fuses and turned it on. Now it won't come out of protection unless I remove the driver board. I pulled all 8 output transistors and they survived (thank you deity of my choice). I figured the bias pots were way off and that was the problem so I set the DMM for 200mA and started over. I couldn't get any readings from either fuse although I still get voltage readings from both.
Do I:
1. most likely have a faulty DMM?
2. focus on the other two fuses assuming the SM is wrong?
3. have a problem with the driver due to the sparky thingy?
4. look for another hobby? (Be kind).
5. leave the fuses in place rather than removing them?
I'm at a loss here and sure could use some guidance (and a bottle of single malt whiskey).
Thanks.
Do I:
Thanks.
