Bolan13
Member
Hi everyone,
I’m running into an issue with the right channel on my Sansui 9090 and am hoping to get some feedback from the Sansui experts here.
The unit was expertly restored a couple of year ago by an AK member here with bypassing the Dolby board. I recently noticed the right channel sounded noticeably thinner.
I did some basic trouble shooting with my multi meter:
Inputs & Sources: Tested via Aux and Tape Monitor inputs using 60Hz and 1,250 Hz test tones from a release on Qobuz, Issue persists identically across both inputs.
Speaker Output Banks & Headphones: Tested on Speaker A and B outputs, as well as through headphones via the front panel jack. The right-channel sounding thinner is present on headphones as well
Speakers & Cabinets: Swapped Left/Right speaker cabinets to rule out driver issues. The low-end loss stays strictly locked to the right channel output of the receiver.
Control Baseline: All testing was conducted with Loudness OFF, Low/High Filters OFF, and Tone controls set flat to establish a direct, un-boosted signal path.
Signal Testing & Voltage Measurements
1. Initial Output Check (At Speaker Terminals):
1,250 Hz Tone: Left = 0.80V AC | Right = 0.89V AC (Channels match closely in upper mids/treble)
60 Hz Tone: Left = 0.70V AC | Right = 0.24V AC (Right channel collapses significantly in the sub-bass)
2. Pre-Out Only (Unloaded / Jumpers Out at 50 Hz):
Left Pre-Out: 0.16V AC
Right Pre-Out: 0.17V AC
Result: Unloaded preamp output voltages match almost perfectly.
3. Main-In Direct Feed (Preamp Bypassed, External Source into Power Amp at 50 Hz):
Left Speaker Terminal: 0.25V AC
Right Speaker Terminal: 0.25V AC
Result: The power amplifier stage operates completely balanced on both channels down to 50 Hz.
4. Normal Operation (Pre-Out Connected to Main-In at 50 Hz):
Left Speaker Terminal: 0.52V AC
Right Speaker Terminal: 0.18V AC
Result: As soon as the preamp stage drives the power amp under normal load, the right-channel low frequency drops by over 60%.
Summary & Question
Because the power amp measures fine directly and the preamp outputs match when unloaded, it appears the right channel preamp is choking under load specifically at low frequencies.
Has anyone encountered this specific load-sensitive low-frequency drop?
Appreciate any insights or advice!
Summary & Question
