I'm replacing the main filter caps on a friends 9090DB. He bought it with a pretty nice recap job about 2 years ago, but it always had a pronounced hum. The original recap included good components, new relay, mostly fine gold and panasonic FCs. As well as diodes and fusistors. But they didn't change out the main filter caps, so I decided to do so and see if that helped with the hum. At the very least, I also hoped to tighten up the bass which wasn't as tight as I would have expected.
I got the replacement parts that are the exact same size, and had a few questions. Pic below
Original on left.
Questions:
Original on left.
- Hot came in on the +
- negative (white) on the marked bottom - .
- Bar as shown connected - to + and was the ground
Questions:
- What filter cap would best for this? It was not part of original implementation. I was thinking a 1uf/250v panasonic film cap. I'm assuming anything film in the 1-10uf range and with voltage that exceeds the caps (100v) would be fine?
- Can I use both sets of the + and - on the new caps?
- As in, put the bleeder resister on unoccupied + and negative, or should I just clip those and have the bleeder resistor on the same as film caps?
- Using the original bleeder resistors is fine I take it?
