bobforapples
Angular banjos sound good
I have been working on a 9090db for the first time, and I am learning alot from reading old posts in this forum.
I am replacing all the fusible resistors with metal oxide flameproof, and I'm going to re-cap the driver and power board. I won't be using Dolby so I do not plan on touching that troublesome board.
I tested the transistors on the driver board, and they all test fine, I got wierd results on the two that are mounted on the top of the heatsinks, but both sides matched. I think the wierd results may be because of where they are in the circuit.
Before I start to order parts, are these the "output transistors" people talk about replacing?
Thanks!
Thanks!
