cortico
Hi, guys, I hope all is good.
Recently, I have replaced my 70's Marantz system with Parasound separates, pretty solid and sweet sound rig. I noticed the Preamplifier (PL/D 2000) has two different input and out options.
The manual says that the Normal output should be used for amplifiers that you are not sure can protect your speakers from DC in the signal path.
Not sure what the Direct Input does. is added/removed from the audio path? The use of both is recommended for best fidelity sound.
Could you please lecture me on Direct Input and Direct Output?
Thanks
Thanks
